10-01-2009 09:23 AM - edited 03-04-2019 06:13 AM
can someone please help me to validate the following interface config:
interface GigabitEthernet0/0
description $CONNECTION TO LAN$
no ip address
duplex auto
speed 100
interface GigabitEthernet0/0.1
description $NATIVE_Data$
encapsulation dot1Q 1
ip address 172.20.1.254 255.255.255.0
ip nat inside
ip virtual-reassembly
interface GigabitEthernet0/0.20
description $CONFIG_CNTR$
encapsulation dot1Q
ip address 192.168.2.1 255.255.255.0
ip helper-address 192.168.200.254 {another DHCP server on HP switch trunked to cat3560 switch which is connected to the Cisco on GI0/0 as the voice switch}
ip nat inside
interface GigabitEthernet0/0.50
description $VOICE$
encapsulation dot1Q
ip nat inside
Q: do i need to give ip add to vlan 50 or i can just leave it part of the native vlan.
thank you in advance
10-01-2009 09:28 AM
You need a VLAN ID for each encapsulation dot1q, and an IP address for each subinterface.
You do not need "ip virtual-reassembly".
10-01-2009 09:50 AM
can i do:
vlan 1 for example: 172.20.2.0
vlan 20 192.168.2.0
vlan 50 172.20.1.0
under int .20 i have an ip add helper to point to another dhcp server, is that the way to do it?
thank you so much for your help.
10-01-2009 10:34 AM
Yes.
Please remember to rate useful posts with the scrollbox below.
