Can two ASA build up a loadbalance such as active/active mode ?
Answered Question
Oct 1st, 2009
Hi, Professionals
I am wondering if two ASA be able to build up a loadbalance such as active/active mode, balance the traffic, ?
thanks in advance,
Yang
Correct Answer by Collin Clark about 7 years 3 months ago
Yes, running the ASA's in active/active is so you can load balance traffic. Here's a link with more information.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080834058.shtml
Hope it helps.
Overall Rating: 5 (2 ratings)
dhananjoy chowdhury Fri, 10/02/2009 - 11:50
Cisco ASA does not provide load balancing by itself, for load balancing you will have to use a Router/ L3 switch or load balancer upstream/ downstream of the ASA devices.
Also for ASA cluster to be in Active/Active, you will have to configure it in multi context mode.
In multi context mode you cannot use features like VPN, dynamic routing, etc.
