meeting place Express 2.x Changing music on hold
Answered Question
Oct 1st, 2009
Is it possible to remove MOH from MeetingPlace Express?
or is it possible to replace the file with an alternative moh file
if so is the file located in
/opt/cisco/meetingplace_express/afs/prompts/en_UK/
Or would any one know the filename I need to look for.
Cheers for any info
Correct Answer by cschlageter about 3 years 9 months ago
I know this is an old system and thread, but incase someone else is out there working with it, yes you are correct, as long as you have language en_UK configured. en_US if you US English selected.
Music on hold file is:
/opt/cisco/meetingplace_express/afs/prompts/en_UK/s304.wav;
just create the file (low quality - 8.000 kHz, 8-bit, mono)
#scp the file to the mpx server,
su root
cp newfile.wav /opt/cisco/meetingplace_express/afs/prompts/en_UK/
cd  /opt/cisco/meetingplace_express/afs/prompts/en_UK
#make backup of original file
cp s304.wav s304.wav.orig
cp newfile.wav s304.wav
reboot
Overall Rating: 5 (1 ratings)
Correct Answer
cschlageter Thu, 08/01/2013 - 13:11
su root
reboot
