Dhcp host pool configuration
Oct 1st, 2009
I'm wondering that is it possible that i create a dhcp host pool Cisco router and this host pool is valid only for specific vendor mac range?
I have a situation that there is several PC's and I have local pool which is only for specific vendor mac and all other vendor's DHCP Discover packet's I relay to different DHCP server?
Here is the config:
ip dhcp pool test
hardware-address 0016.caff.ffff #I tried to match only mac-address which start from 0016.ca#
lease 0 1
int vlan 1
ip add
ip helper-address
Packet's are coming from same Vlan.
Giuseppe Larosa Thu, 10/01/2009 - 23:00
Hello Jarmo,
you would need to be able to use an ACL the line hardware-address 0016.caff.ffff looks for that specific mac address not a range.
I've searched IP addressing services command reference to see if there is an option to invoke a MAC ACL
Also I'm not sure that for non matching clients the ip helper-address option is used.
Hope to help
komuja1 Sun, 10/04/2009 - 13:14
Hello Giuseppe,
thanks for your reply.
I will try to use ACL with pool or then I configure the network so that I have dhcp pools where I check inside the dhcp discover packet (host-id field) and the pools make decision base on this "host" field..hope it works :)
