CUCM configuration
Oct 1st, 2009
Wanted to ask a simple question.
When the a cluster has for example 2 subs and a pub, to configure a user one can login to any server and perform the change since database is common? Or whats the common practice?
Overall Rating: 4 (1 ratings)
Jaime Valencia Thu, 10/01/2009 - 13:20
  • Cisco Employee,
  • Hall of Fame,
    2011
If you mean configure a user to access CUCM admin it doesn't matter where you create it, it can access any server in the cluster
java
if this helps, please rate
gmcleveney_2 Thu, 10/01/2009 - 16:05
Thanks.
Same thing should be true for configuring phone too ? For user on sub-2 being configured from sub-1.
Jaime Valencia Thu, 10/01/2009 - 17:48
  • Cisco Employee,
  • Hall of Fame,
    2011
Yes, same thing for phones.
That's the whole concept of having a cluster, whatever you configure in 1 server replicates to the others
java
