Access-lists with tpc-udp object-group
Answered Question
Oct 1st, 2009
I am converting from my pix to a ASA 5505.
I am having issues making an access list that includes a tcp-udp object-group.
Is there a recommended practice for doing this?
Correct Answer by JORGE RODRIGUEZ about 7 years 7 months ago
You don't defined in your post where network group hosts are comming from nor where is xxx.xxx.xxx.xxx host, but looking at your acl name outside_access_in I will assume xxx.xxx.xxx.xxx is an inside host and your network group are hosts from the outside , the inbound rule will read as:
access-list outside_access_in extended permit tcp object-group Test_Group host xxx.xxx.xxx.xxx object-group Test
access-list outside_access_in extended permit udp object-group Test_Group host xxx.xxx.xxx.xxx object-group Test
in above permit tcp and upd inbound rules example you must use network object group follow by destination host inside xxx.xxx.xxx.xxx follow by service tcp-udp test object-group
Overall Rating: 5 (1 ratings)
JORGE RODRIGUEZ Thu, 10/01/2009 - 14:44
  • Green, 3000 points or more
These are the guidelines.. you can create service group that includes tcp-udp ports but when creating the access list for example an inbound acl you must specify in your permit rule either udp or tcp, so you will need two access-list for each the udp and tcp protocol using same sevrice tcp-udp group.
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/no.html#wp1750094
jsaumer2006 Thu, 10/01/2009 - 18:02
When I try and make the access list entry it is giving me the following error message in the ASDM
[ERROR] access-list outside_access_in line 4 extended permit object-group Test_Group object-group Test host xxx.xx.xx.xxx
specified object group has wrong type; expecting protocol type
The object-group Test is in the config as the following:
object-group service Test tcp-udp
port-object range 20 21
port-object eq 22
port-object eq 55
port-object eq 5631
port-object eq 5632
port-object range 9500 9505
port-object eq www
The Test group is made as the following:
object-group network Test_Group
network-object host Test_3
network-object host Test_2
network-object host Test_1
network-object host Test_4
Thanks in advance
Correct Answer
JORGE RODRIGUEZ Thu, 10/01/2009 - 19:36
jsaumer2006 Fri, 10/02/2009 - 05:30
I think my problem was that I was using the ASDM top put in the rules.
Using the command line, I didn't have any issues.
Thanks for the guidance.
JORGE RODRIGUEZ Fri, 10/02/2009 - 05:56
Jayson, glad worked out .. PLS rate helpful post if helped.
