needed help to find call history report in CUCM 7...
Oct 1st, 2009
I am little bit confused with this topic. I need a report which displays all the calls made by users on daily basis. When I see in the discussion forums, people are talking about CAR tools but I am not sure if it can be used in CUCM 7 or not. When I go to the CU Servicability->tools menu, I can see only CDR Management. When I checked in the CUCM Administration --> Application-->Plug ins it does not show any thing like that in the list. I really need somebody's help to figure out how can I generate the call history report.
Thanks a lot in advance...
Arjun
kcarjun2002 Thu, 10/01/2009 - 14:18
Thanks for the prompt response. Can you briefly explain the process on how to set it up if you don't mind...!
Thanks again
kcarjun2002 Fri, 10/02/2009 - 08:05
I found that the service was already installed and running. I assigned myself as a member of CAR admin group. When I try to logon to the CAR webpage, I get the following error message:
The requested resource
(/car/j_security_check) is not available.
Is there any security seetings that I need to make changes?
Jaime Valencia Fri, 10/02/2009 - 11:21
Just to make sure, you're using the link under serviceability right???
If yes, take a look at this bugs:
CSCsm21561
CAR url needs to be changed in ccmservice page
CSCsm34607
Getting error when Loging into CAR
java
if this helps, please rate
