Unknown ipsec error.
Oct 1st, 2009
I have an 871 with tunnels to two other 871s. The log on the router with two tunnels has a lot of messages like this:
IPSEC(crypto_get_cm_handle_from_pak): Failed to create access pak subblock
I have not found any docs on this. Can anybody either direct me to a reference or explain it?
Joe
reindl_mc Mon, 10/12/2009 - 00:13
hi joe
I have the same problems on my 1812 router and on my 871 router. I have IOS Version c870-advsecurityk9-mz.124-15.T10.bin runnning.
Which IOS do you have active ?
Since this IOS is installed I have the problem that VPN Tunnel is showing active(show crypto isakmp sa) but from time to time packets are encrypt, on the other site not decryp. Do you also running this behaviour ?
thanks
