CCA 2.1 - Changing outgoing access number
Oct 1st, 2009
For a UC500 we just installed today, the client wanted to change the access number to dial out from "9" to "8".  I tried changing it in CCA, but I received an error and would not let me apply.    However, when I went into CLI to make the change, some of the dial-peers were already switched to "8" for the lead number and there were a couple that were not.   The translation-rule was not changed and neither were the commands under the "telephony-service" area.
Marcos Hernandez Thu, 10/01/2009 - 15:14
  • Blue, 1500 points or more
What was the exact error that you received? Can you provide troubleshooting logs? We tried with a 2.1 system and the problem does not occur...
Marcos
brandon.kallas Thu, 10/01/2009 - 15:23
I emailed you the log file from when the change was attempted.  I did not get a specific error message, just the access-code box was highlighted in red as well as the access-code boxes in the section below for each of the dial-out options.   At this point it would not let me Apply the changes... however it looked like it still applied some of them, just not everything.
Maulik Shah Thu, 10/01/2009 - 15:41
  • Silver, 250 points or more
Thanks - have our engineering folks looking at this - hope to get some info back soon. Just for clarification:
- was this a new install that you were using CCA 2.1 with?
- they have a PRI and FXO trunks and you want 8 to be the access code for both trunks?
Maulik Shah Thu, 10/01/2009 - 16:09
Brandon
  Were you setting up multi site (between UC500s) on this deployment using CCA? If so that maybe an issue as by default the inter site access code is 8.
