Block Foxy by CSA
beckman.yang
What ports of foxy used ? If I want block foxy running by user , how should I do ?
thanks
jan.nielsen
Level 7
Level 7
You should start by not allowing people to install software themself on your pc's. Then you should make sure that no one can connect a pc to your network, unless you have control over it.
Dear Sir ,
If foxy had been installed by user , how do I block it ?
thanks
