TCP Splicing
Oct 1st, 2009
Please can you tell me what is TCP splicing and how it works / helps.
I am having issue in HTTP redirect using CSM.
After my investigation I suspect the CSM takes age to reply SYN_ACK for SYN packets because of that internmittently redirect is not working.
I hope some one should have had the same issue, can you please share with how to fix this?
Gilles Dufour Fri, 10/02/2009 - 03:43
  • Cisco Employee,
TCP Splicing is explained here :
http://www.linuxvirtualserver.org/software/tcpsp/index.html
But it is not related to your issue.
Do you have a sniffer trace showing the problem ?
The only reason for the CSM not to respond immediately to a SYN is if it is overloaded.
It could also be because the SYN is dropped in the network.
Several 'show mod csm x tech' should show if the box is overloaded. Check counter with words like fifo, overflow, ...full.
Gilles.
mahendra.raj Fri, 10/02/2009 - 03:59
Hi - Thanks for your reply.
I have attached the sniff traffic (Public IP is hidden)...
when ever I get the page time out.. I am seeing a firewall (Nokia) log saying
"tcp packet out of state first packet isn't syn tcp_flags syn-ack"
At the same time I can see on the CSM Conns = 1 under Vserver
sh module csm 3 vservers name MY_WEB-RD detail
MY_WEB-RD, type = SLB, state = OPERATIONAL, v_index = 52
virtual = 10.10.10.10/32:80 bidir, TCP, service = NONE, advertise = FALSE
idle = 3600, replicate csrp = none, vlan = ALL, pending = 30, layer 4
max parse len = 2000, persist rebalance = TRUE
ssl sticky offset = 0, length = 32
conns = 1, total conns = 574
current load = 2, transition count = 0
Default policy:
server farm = HTTP_REDIRECT, backup =
sticky: timer = 0, subnet = 0.0.0.0, group id = 0
Policy Tot matches Client pkts Server pkts
(default) 556 868 343
Please advice this CSM is on our core, how safe it is to run the tech-support on this? I am bit afraid to run tech-support....!!!
In addition to that... I have bypassed the Nokia firewall and I tried it works perfectly no drops at all.. But I have this issue only when I go through the Nokia Firewall...!!!
Thanks for your help in advance...
Gilles Dufour Fri, 10/02/2009 - 04:07
  • Cisco Employee,
do you have active and standby firewall ?
Is it possible that the CSM response goes to the wrong firewall ?
I know nokia firewalls use multicast mac-address which the CSM does not like very much...is the csm directly connected to the firewall ? Could you put the MSFC in between and route between msfc and firewall ?
G.
mahendra.raj Fri, 10/02/2009 - 04:11
well.. the CSM is in Bridge mode and MSFC routes all the traffic to NOKIA...!!
mahendra.raj Mon, 10/05/2009 - 23:35
Hi All,
Any further lights on this for me to fix this...please?
