10-02-2009 12:23 AM - edited 03-10-2019 04:42 PM
I would like to setup password aging for tacacs authentication to cisco devices.
The problem is that in the group setup in the ACS, I don't have the section password aging (as described in the help topic).
I'm using ACS v3.3
Thank you for your help !
Solved! Go to Solution.
10-02-2009 05:48 AM
Thats gr8.
password change is supported by SSHv2. SSHv1 doesn't support the necessary
message types to initiate a password change sequence.
There is also a defect related to this. However, this will work with recent IOS versions.
CSCin91851: Support keyboard-interactive authentication method
1st Found-In: 12.4T
Fixed-In:
12.4(10.1)T
12.2(33)SXI
12.4(17.9)M
12.2(32.8.11)SX142
12.2(33.1.10)SXH
12.4(13f)M
12.2(33)SXH2
12.2(32.8.11)XJC153.1
12.2(32.8.1)YCA172.24
12.4(22.3.4)PIC1
JK
10-02-2009 03:55 AM
In order to use password aging feature on ACS 3.3, you first need to enable it.
Here are the steps:
On ACS > Go to interface configuration > Advanced Options > look for "Group-Level Password Aging" > check this option > hit submit.
Noe go back to your group > Look for "Jump to" option on the top > click on drop down menu > select password changing.
You may refer this link while configuring password aging.
JK
10-02-2009 05:28 AM
Great thank you !
Password aging feature works on SSH ?
10-02-2009 05:48 AM
Thats gr8.
1st Found-In: 12.4T
Fixed-In:
12.4(10.1)T
12.2(33)SXI
12.4(17.9)M
12.2(32.8.11)SX142
12.2(33.1.10)SXH
12.4(13f)M
12.2(33)SXH2
12.4(22.3.4)PIC1
JK
