10-02-2009 12:35 AM - edited 03-04-2019 06:13 AM
I am new to this so please take it easy on me. What kind of interface module do I need in order to hookup a Cable dsl modem to a 2524 or 2621 router? I've tried looking but can't find anything. Also how to I get the ios to upgrade these routers? Any help would be greatly apreciated. Thank you.
10-02-2009 03:07 AM
You would need an additional ethernet for the 2621, but nothing is possible on the 2524.
software updates are obtained buying a support contract.
10-02-2009 09:48 AM
Thank you for the response. But, are you sure? Isn't there a WIC ADSL module that goes into either the 2600 series or 2500 series router. If so, I just don't know the part number. Also to obtain a support contract, can anyone get(pay) for this? Thanks
10-02-2009 11:04 AM
Hi, for cable you will find that the only practical solution is to use the modem given by the cable company that has an ethernet interface.
Your organization should pay for the support contract.
Please remember to rate useful posts with the scrollbox below.
10-02-2009 11:23 AM
I'm assuming I need a static IP for this from the cable internet provider. Correct?
10-02-2009 10:33 AM
I guess I didnt understand the question correctly, please feel free to correct me anywhere you think I missed.
Are you trying to connect the ADSL (from Telco) directly to a Router? Or from the Cable Modem's Ethernet Interface?
If its Ethernet Interface (as most of the N American Telcos do) then all you need is a FE/E Interface on the Router and it should be fine. However if its about connecting the ADSL Cable terminating on the Router itself, then there is a lot information you will need from the provider before you place any order.
Sam Wilson
10-02-2009 11:21 AM
I'm trying to connect directly from the cable modem ethernet interface to the router. Is their a WIC or module that Cisco has that connects to the back of the router and then I connect my ethernet modem cable to this wic/module? Or is the connection from: cable ethernet port to FE/E interface on the router? Thanks
10-02-2009 12:31 PM
As mentioned above, you would need an additional ethernet interface so you can connect the cable modem one side, and you line on the other.
However you will find that 2621 are quite obsolete today and you would do better with a new router as small as an 851.
