Jatin Katyal Fri, 10/02/2009 - 03:48
  • Cisco Employee,
Unfortunately, this is not possible.
You can have export a list of all users in the ACS internal database to a text file named users.txt bys using csutil utility and that will be only with ACS windows.
For detailed steps, you may refer:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.2/user/guide/A_CSUtil.html#wp393825
JK
tmsundar81 Fri, 10/02/2009 - 03:59
I have taken the backup its a .dmp file, how can i open it...
Jatin Katyal Fri, 10/02/2009 - 04:41
  • Cisco Employee,
You can open .dmp file in notepad but that will not provide any info as its not user readable.
You need to export the lsit of users in .txt extension
here is the command that you need to run from the command prompt where ACS is installed
start > run> cmd > go to this dir
C:\Program Files\CiscoSecure ACS v4.2\bin>net stop csauth
CSUtil.exe -u user.txt
C:\Program Files\CiscoSecure ACS v4.2\bin>net start csauth
Then you can easily access user.txt file in notepad.
JK
tmsundar81 Fri, 10/02/2009 - 05:11
Is it possible to do with out console connection, as i have only remote access...
Jatin Katyal Fri, 10/02/2009 - 05:37
  • Cisco Employee,
Sorry, it won't work without console connection.
JK
