Sup 720 failover
Answered Question
Oct 2nd, 2009
We have installed 2 SUP 720 into 6509 switch and would like to change default failover time to reduce delay.What is the config we need on sup 720?
Regards.
Correct Answer by Wilson Samuel about 7 years 9 months ago
In general Sup 720s can be used in two modes:
1. SSO
2. RPR
1. In SSO mode the L-2 traffic is never interrupted even if the active Sup fails, however if you want the L-3 traffic also to flow un interrupted, then one must enable NSF along with the SSO
2. RPR, all the traffic will get dropped and then with in a minute's time the Stdby Sup becomes active and all the ACL are reprogrammed.
Not sure if I got your question correctly, however I presume this should answer your concern.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/nsfsso.html#wp1119694
Sam Wilson
Overall Rating: 3 (1 ratings)
Correct Answer
Wilson Samuel Fri, 10/02/2009 - 10:27
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
1. SSO
2. RPR
Sam Wilson
