CSS/ASA can users on the inside access the VIP by its Public IP address
Answered Question
Oct 2nd, 2009
I've an ASA with a DMZ on which the CSS is connected.
Outside users connect to a public IP address which is statically NAT'd to the VIP on the CSS.
All is working well, but the customer wants to be able to use the public IP address (or DNS) from the inside network of the ASA.
Is this possible, as the traffic would need to go inside to outside then outside to DMZ and back?
any help appreciated
Cheers Tony
Correct Answer by acomiskey about 7 years 5 months ago
Tony, this is pretty simple actually.
If your existing static looks something like this for access from the outside...
static (dmz,outside) 1.1.1.1 2.2.2.2 netmask 255.255.255.255
all you have to do is add this static
static (dmz,inside) 1.1.1.1 2.2.2.2 netmask 255.255.255.255
Then anyone on the inside going to 1.1.1.1 will be sent do 2.2.2.2 in the dmz.
Overall Rating: 5 (1 ratings)
Correct Answer
acomiskey Fri, 10/02/2009 - 09:12
  • Green, 3000 points or more
tholmes@cistek-... Fri, 10/02/2009 - 10:02
Hello Acomiskey,
Thanks for your reply, you know... I've been configuring PIX firewalls (since 5.1, ASAs and FWSM, for hundreds of years now, L2L VPNs, SSL VPNs, RA, CSSs and even the odd CSM.
I did a 10 interface ASA using VLANs last month, that actually hurts!
But every now and again, I get a mental block and have to start the learning process all over again.
Is it just me? :-)
Thanks for your help, its now working, I'll happily provide a 5 rating
Cheers Tony
