WCS Local vs Guest
Oct 2nd, 2009
I have WCS version 4.2.62.11, upon creating temporary guest accounts what is the difference between using 'Local Net Users' vs. 'Guest Users' feature. I look under both and they each have the same guest accounts I have created. Which is the Cisco standard best practice to use for creating temporary guest accounts and which should I use for creating permanent user accounts?
Lucien Avramov Fri, 10/02/2009 - 10:51
  • Red, 2250 points or more
Guest users are the users that will connect on your guest WLAN (or SSID). It's a WLAN where web-auth is enabled.
Can you paste a screenshot of where you see the local net users?
Local management users are for loggin in WCS / WLC.
Trending Topics - Security & Network
