Warning message
Possibility to implement a MoH source on an SRST router
Oct 2nd, 2009
Hi ,
Assumin we have a centralized CUCM deployment, in order to save bandwidth, Is it possible to implement an MoH source on a SRST router. The source should be utilized all the time not only when the WAN is down.
best regards,
Jaime Valencia Fri, 10/02/2009 - 10:43
  • Cisco Employee,
  • Hall of Fame,
    2011
Yss, you could have easily searched SRST + MOH in CCO instead and this is the 1st match
Integrating Cisco Unified Communications Manager and Cisco SRST to Use Cisco SRST as a Multicast MOH Resource
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/admin/srst/configuration/guide/srs_moh.html
You could have also searched NetPro and get a lot of hits on the topic
java
if this helps, please rate
