SIP trunk issue
Oct 2nd, 2009
I have two CME systems connected using a SIP trunk. In both systems, SCCP was used as a signaling protocol. In that situation all works properly. Then, all phones in one site are converted to SIP. Local calls on this site work properly, but calls across the SIP trunk don't work. When calling from SIP side to SCCP side, a reorder tone is heard. When calling from SCCP side to SIP side, the phone at the SIP side rings but no voice is heard.
Any idea about how to solve it?
paolo bevilacqua Fri, 10/02/2009 - 12:28
  • Hall of Fame,
    Founding Member
To avoid this kind of problems and more, leave phones in SCCP as they are designed and tested to be like that.
You will also able to retain you language localization that is Spanish if I'm not wrong.
Nicholas Matthews Mon, 10/05/2009 - 05:28
  • Red, 2250 points or more
Try these:
voice service voip
allow sip to sip
no supp sip refer
no supp sip moved
These are general practice SIP-SIP commands that offer higher reliability for supplementary services.
-nick
