Can not Ping Laptop from Router
Oct 2nd, 2009
Hello ,
I just want to know ,what is wrong here.
I have laptop connected to Router 2620 on the same network range(LAN).
Router 192.168.10.1/24
ip route on router 0.0.0.0 0.0.0.0 192.168.10.10
Laptop 192.168.10.10/24
Gateway on Laptop is 192.168.10.1
ROUTER<--------->Laptop
No ACL ,NO ROUTING Protocols !!!
I can ping from Laptop->>>>Router
I can NOT ping fron Router-->to Laptop.
Any Help Please
DAK
Lucien Avramov Fri, 10/02/2009 - 12:46
You have a firewall software on y our laptop: either windows firewall or some antivirus program
Davy Ad Fri, 10/02/2009 - 14:54
i turned off the window firewall and fine tuned it to allowed ICMP and Echo ,still the same .
Any help again will be great
Lucien Avramov Fri, 10/02/2009 - 13:02
if the ping is done the entry is there.
Its a firewall issue on the pc or a firewall between pc and switch
Davy Ad Fri, 10/02/2009 - 14:52
Thanks i did the same thing you said it shows the ip address and the PC connection was up.
I turn the window firewall off before and there was no pin ,even i fine tunned it, allowed Echo and ICMP in window firewall
Please let me know what else could it be
glen.grant Fri, 10/02/2009 - 15:18
Source ping the pc from router interface of the subnet the pc is on , if it doesn't ping its a pc issue , this takes out default gateway settings etcc on the pc. You don't need a default static on the router if the pc is directly attached to the router.
Lucien Avramov Fri, 10/02/2009 - 15:28
run a wireshark packet capture on your pc, you probably wont be seing any packets if there is a firewall blocking traffic that was not disabled.
johnlloyd_13 Fri, 10/02/2009 - 17:49
try changing your cable and try removing the static route in the router and gateway settings in your laptop. do ping tests again.
Lucien Avramov Fri, 10/02/2009 - 18:14
why changing the cable when it pings from pc to router but not from router to pc. this doesnt make much sense.
it's a firewall issue.
Davy Ad Sat, 10/03/2009 - 12:28
Thanks Lucien,
I will try and check my PC again.I tried it on another Laptop with Vista and it was the same issue.
