ASA5540 throughput
Answered Question
Oct 2nd, 2009
ASA5540 firewall throughput is 650Mbps, 3DES/AES VPN throughput is 325Mbps.
Is the firewall total throughput 650M+325M? Or 650M?
thanks,
Correct Answer by Patrick0711 about 7 years 5 months ago
650 is the total amount of aggregate throughput the device will support.
The 325Mbps rating is simply specifying that the device can process 325Mbps of 3DES/AES encrypted data. This data would fall within the 650Mbps limit.
Overall Rating: 5 (1 ratings)
Correct Answer
Patrick0711 Fri, 10/02/2009 - 15:11
  • Bronze, 100 points or more
