After restart CUCM 5.1.3 not able to reach from the network
Oct 2nd, 2009
I faced one different issue, i restarted the CUCM 5.1.3, after that i am not able to reach the server. But i m able to reach all other servers in the same cucm cluster. From the particular server I am able to reach the all out side network. But from the PC I am not able to reach particular server. Aftre approximate 1.30 minutes automatically start to work. But one thing i noticed that in the same time i m able to ping all other subscibers from this particular server.
If any body can give me the idea on this issue it will be very much thankful.
Sunish
gogasca Mon, 10/05/2009 - 01:11
mmm...
"But one thing i noticed that in the same time i m able to ping all other subscibers from this particular server"
I dont think its the server...best thing is get local access to server connect to same switch and verify:
1. NIC is active
2. CUCM blocking other subnets other than its susbcribers
3. Connect to pc and ping from same switch
Follow up with your network admin, and check traceroutes
