ssh for 2611 router
Oct 2nd, 2009
I have tried to configure ssh on 2611 router but there is no 'crypt key generate rsa' command in global configuration mode.
Hear is the result of 'show version' command. Any ideas why? Thanks
IOS (tm) C2600 Software (C2600-I-M), Version 12.3(6a), RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 02-Apr-04 19:17 by kellythw
Image text-base: 0x80008098, data-base: 0x80C83D68
ROM: System Bootstrap, Version 12.2(6r), RELEASE SOFTWARE (fc1)
router6 uptime is 29 weeks, 4 hours, 40 minutes
System returned to ROM by reload at 14:33:45 EST Fri Mar 13 2009
System image file is "flash:c2600-i-mz.123-6a.bin"
cisco 2611 (MPC860) processor (revision 0x00) with 26624K/6144K bytes of memory.
Processor board ID JAD06150TU3 (3727349761)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
router6#$rocessor (revision 0x00) with 26624K/6144K bytes of memory.
cisco 2611 (MPC860) processor (revision 0x00) with 26624K/6144K bytes of memory. ^
% Invalid input detected at '^' marker.
router6#Processor board ID JAD06150TU3 (3727349761)
Overall Rating: 4 (2 ratings)
glen.grant Sat, 10/03/2009 - 03:47
Yes you need a new image for the router. The image name will have a "K9" somewhere in the image name indicating it is a crypto image that will support SSH .
