IP Interface ACLS, and CEF "receive" adjacencies
Oct 2nd, 2009
In regards to configuring an SVI with ip address 10.10.10.1 and applying the following ACL inbound:
"permit ip 10.10.10.0 255.255.255.0 any"
Would ICMP packets destined to the SVI be forwarded for an ACL lookup or since this is a "receive" adjacency in CEF and its traffic destined to the control plane than would only rACL's or cOPP be needed for protection.
Please let me know and I can clarify further.
Thank you
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Sat, 10/03/2009 - 01:45
  • Hall of Fame,
    Founding Member
Hello Thomas,
the ACL will process ICMP packets destined to the SVI and it will allow them.
but you need to write it using wildcard mask:
permit ip 10.10.10.0 0.0.0.255 any
you can test using a modified version of the ACL
access-list 111 permit icmp 10.10.10.0 0.0.0.255 host 10.10.10.1
access-list 111 permit ip 10.10.10.0 0.0.0.255 any
int vlan 10
no shut
ip access-group 111 in
attempting to ping 10.10.10.1 should work and you should see counters increasing in first line of ACL 111
with
sh ip access-list 111
CoPP is more smart and it can introduce a rate-limiting action to protect CPU.
Hope to help
Giuseppe
tbowlby1980 Sat, 10/03/2009 - 09:59
Hello Giuseppe,
I'm in the process of testing this today and really appreciate the feedback.
Thank you
