Easy VPN ACL Traffic-Triger Tunnel Initiation
Oct 3rd, 2009
I made in Dynamips topology with three routers in the row. The first and the third routers I am using as a Easy Server and Easy Client, with loopback interfaces 10.2.2.1/24 and 10.3.3.1/24 to simulate LAN, respectivly on the routers. I am also successfully configure NAT on both routers.
I am trying to connect EasyVPN Remote Router with the EasyServer.
When I am using network-extension or network-plus mode and auto connection, tunnel will be established but all traffic from remote site is passing through tunnel to the Server Site. Packets from the Remote Site will be deencapsulate on the Server outside interface and pass to the LAN. Ping between LAN works successfully but I can not ping middle Router that simulate Internet Provider (to simulate Internet connection). Ofcourse this is maybe normal because remote packets being deencapsulate on the Server outside interface and ping continue to the middle router with the source address of 10.3.3.1 that is unreachable for provider. When I put static route to point for 10.3.3.0/24 network to the Server Router ping was successfull. Hm...?? any idea to reapir this small issue?
Other option that is more important to me is how to apply traffic-trigger connection from remote site? I put "mode acl ezystart" command on the remote site where ezystart ACL permit ip from remote site to the server site. After that I tunnel won't be established!
Configuration outputs (some line is missing due to simplify important parts from config)
Server:
crypto isakmp policy 10
crypto isakmp client configuration address-pool local ezypool
crypto isakmp client configuration group ezygroup
key cisco123
pool ezypool
acl split
crypto dynamic-map dynmap 10
set transform-set ezyset
reverse-route
interface Loopback0
ip address 10.2.2.1 255.255.255.0
ip nat inside
interface Ethernet0/0
ip address 2.2.2.1 255.255.255.0
ip nat outside
crypto map ezymap
ip route 0.0.0.0 0.0.0.0 2.2.2.2 //static route to the middle router/
ip access-list standard split
permit 10.2.2.0 0.0.0.255
ip access-list extended nonat
permit ip 10.2.2.0 0.0.0.255 any
ip nat inside source list nonat interface Ethernet0/0
Client:
crypto ipsec client ezvpn ezyvpn
connect auto ... her I am trying connect acl ezystart
group ezygroup key cisco123
mode network-extension /or network-plus
peer 2.2.2.1
username cisco password cisco
xauth userid mode local
interface Loopback0
ip address 10.3.3.1 255.255.255.0
ip nat inside
crypto ipsec client ezvpn ezyvpn inside
ip address 3.3.3.1 255.255.255.0
ip nat outside
ip route 0.0.0.0 0.0.0.0 3.3.3.2
ip nat inside source list nonat interface Ethernet0/0 overload
permit ip 10.3.3.0 0.0.0.255 any
ip access-list extended ezystart
permit ip 10.3.3.0 0.0.0.255 10.2.2.0 0.0.0.255
Any ideas?
