wlan controller
Answered Question
Oct 3rd, 2009
whats the trick to do TFTP BACKUP? It seems not to like my regular tftp client...
Correct Answer by d-berlinski about 7 years 2 weeks ago
Here is a screenshot to upload a config file to a tftp server. See attached file.
Overall Rating: 5 (2 ratings)
weterry Sat, 10/03/2009 - 09:52
make sure you are doing the "upload from controller" not "download to controller".
Also, make sure your file path is "/".
The TFTP prompt doesn't take a format of "c:/....."
Other than that, it should work.
can you tell us what your exact configuration for tftp looks like ( from the controller gui)?
drosenbaum Sat, 10/03/2009 - 11:24
you hit it on the head the issue is in the formatting and also someone said the cliend has to be tftp32d
weterry Sat, 10/03/2009 - 12:42
tftpd32 is good when doing the downloads of software code. Some TFTP clients don't handle files larger than like 32MB. Thats why tftpd32 is usually suggested.
As for filename, if you are uploading the configuration to the tftp server (to backup), I suppose this is just where you say what you want the filename saved as.
drosenbaum Sat, 10/03/2009 - 15:26
good info, anyone have a screen shot of the tftp page with an example of a good path and filename?
filiberto.aguirre Tue, 02/09/2010 - 17:53
Hi d-berlinski
Did you use tftp32 or wich one?
Currently I have the problem when I write  the File Path in order to upload a file AIR-WLC2100-K9-6-0-188-0.aes to controller
I tried with TFTP desktop,and solarwinds  I put file in c:/, in the FIle Path field I wrote / (base on the example shown in config guide file)
in file name field  the name of the file; but it did not work.
I will try with \ in file path base on your example..
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
