1800 serries router booting problem
Oct 3rd, 2009
When poweron router ,after loading the ios sho this message"Port Statistics for unclassified traffic is not turned on"
And don't proceed.
Plz help me
Giuseppe Larosa Mon, 10/05/2009 - 10:07
Hello Eftekar,
sorry for the basic question :
have tou tried to type enter to see if it goes on?
There are any specific modules installed o it?
An idea could be the following:
power off
remove all parts that can be removed
try again to power it.
another possibility:
try the password recovery procedure to set confregister to have the device to boot without reading the configuration file
if in this way it completes the boot is something to be noted.
Hope to help
eftekhar_a Mon, 10/05/2009 - 10:53
I already try to proceed with password recovery procedure before i submit here but failed.
In my router removable parts only flash card and wic(serial interface.
thanks for ur suggesstion.
Will i try to remove this component?
Plz give me ur openion.
Giuseppe Larosa Mon, 10/05/2009 - 11:29
Hello Eftekar,
yes I would remove also that in an attempt to get the device to finish the boot process.
Hope to help
