Two nat - One Public IP
Answered Question
Oct 3rd, 2009
I have one public Ip address and wants to nat with one DMZ address and one insdie address
DMZ address for smtp ( anyone from outside should be able to connect to smtp server)
Inside address for http ( anyone from internet should be able to access web-server )
Is this possible.
Correct Answer by Jon Marshall about 7 years 4 months ago
"Can I do the same without using ASA external (Outside) IP.
Assuming I have one free public IP."
Yes, as long as the public IP address has been assigned to your company.
The static statements would change slightly ie.
assuming free public IP - 195.17.17.10
static (inside,outside) tcp 195.17.17.10 80 web-server-ip 80 netmask 255.255.255.255
static (dmz,outside) tcp 195.17.17.10 25 mail-server-ip 25 netmask 255.255.255.25
"Is similar scenario documented on cisco documentation. Any Help."
Pretty much any docs on ASA configuration will include this so a quick search "ASA configuration guides" would give you a list of docs to use.
Jon
Overall Rating: 4 (1 ratings)
jan.nielsen Sat, 10/03/2009 - 13:33
Certainly,
If your public address is the one assigned to your outside interface, this is how its done.
static (inside,outside) tcp interface 80 web-server-ip 80 netmask 255.255.255.255
static (dmz,outside) tcp interface 25 mail-server-ip 25 netmask 255.255.255.255
dhananjoy chowdhury Sat, 10/03/2009 - 22:14
Also, in addition to the static NAT statements, you will have to allow TCP port 80 and port 25 on your OUTSIDE interface Access-List.
Amin Shaikh Sun, 10/04/2009 - 08:39
Correct Answer
Jon Marshall Sun, 10/04/2009 - 08:50
Jon
