7915 Phone problem with 7962 on Call Manager 6.1.3
sebastiandm Sun, 10/04/2009 - 08:19
When you say it is not working what exactly is not working. Is it not booting up or are the lines not appearing etc.
Have you created a new phone button template and added to the device and profiles ?
Stoyan Stoitsev Sun, 10/04/2009 - 22:32
To get it working you have to go to Phone Configuration and in Expansion Module Information select the appropriate modules.
To create a phone button template:
- go to Phone Button Templates
- copy Standard 7962G SCCP, rename it and save it
- then according to the number of modules create the corresponding number of speed dials or lines.
BR,
Stoyan
