Cisco 4006 problem
Oct 4th, 2009
I am having Cisco 4006 switch and I have connected three cisco 2950 switch through fiber connecter. All the three switchs are showing in CDP neighbor but un able to ping one switch. I have cleard the mac table , cleared the trunk but one switch is showing cdp unable to ping .
Giuseppe Larosa Sun, 10/04/2009 - 07:24
  • Hall of Fame,
    Founding Member
Hello Thiru,
if the link is an 802.1Q L2 trunk check if there is a native vlan mismatch on the two sides
use
sh int typex/y switchport
check also the list of vlans allowed on both sides.
Hope to help
Giuseppe
thiru.vel10 Mon, 10/05/2009 - 02:08
HI Giuseppe,
Thanks for this Destils.
There was problem in Module , the Service Engineer is faulty. Hence i have removed the switch which is connected from that faulty module and connected to another working switch. Now everything seems normal . let you know if am getting anythings. :)
