10-04-2009 11:43 AM
I want to know if I can be able to use my wireless printer when connect to VPN network.
10-04-2009 01:19 PM
Kendal, what type of VPN? RA VPN or L2L..
If RA vpn all depends, if far end VPN gateway is operating as a Full tunnel VPN you will not be able to access local LAN resources at your end, that includes wireless printer. On the other hand if VPN gateway is split tunnel VPN then you can.
If L2L vpn should be able to have local lan resources fine including wireless devices.
01-08-2023 05:48 AM - edited 01-08-2023 05:49 AM
If you are connected with a VPN and have any desire to print on a nearby Bluetooth printer, you want to make your device visible on the local network. To do this, go to your VPN settings and search for the option to make your device visible on local networks. This will vary depending upon your VPN supplier.
01-09-2023 01:31 AM
If you are refering to a site to site VPN then you will have local LAN access. If you are refering to remote access VPN (AnyConnect) you will have local LAN access if your VPN is using split-tunneling and the remote network IPs do not overlap with the local LAN you are connecting from. If it does overlap, then additional configuration is required on the VPN headend to allow local access if it is not already in place.
If you are connecting via AnyConnect and tunnel-all traffic is being used there would also need to be additional configuration done on the VPN headend to allow local LAN access.
So local LAN access is possible in all cases, it is just a matter of configuration to make it possible.
