Failover Scenario with EasyVPN
Oct 4th, 2009
Si,
Looking for advice and config help on scenario where Branch_Office is connected to Head_Office using service provider MPLS cloud.
we are looking for failover solution so that branch_office still reaches Head_office even if the MPLS link fails.
On Branch Office we have DSL connection, we thought of having EasyVPN with HQ if MPLS connection fails.
Plz comment and help in EasyVPN config to failover when MPLS goes down
Remote_Office_RTR_Config ===
interface FastEthernet0/0
description connected to LAN_segment_Shrj
ip address 192.168.200.1 255.255.255.0
speed auto
description Connected to MPLS_Cloud_du
ip address 172.15.20.251 255.255.255.252
router ospf 100
redistribute bgp 881
network 192.168.200.0 0.0.0.255 area 0
router bgp 881
no synchronization
bgp log-neighbor-changes
redistribute connected
redistribute ospf 100
neighbor 172.15.20.252 remote-as 1050
no auto-summary
auraza Fri, 10/09/2009 - 13:45
Instead of doing ezvpn, set up a GRE/IPSec tunnel that is always up and make sure routing prefers the MPLS over the GRE/IPSec. When MPLS fails, it will fail over to the GRE/IPSec tunnel automatically.
PS. please rate the post.
bwilloby46 Mon, 10/12/2009 - 06:20
Can you elaborate on an example of this type of configuraiton? We are in the process of doing the same thing to back up our MPLS links with DSL. Are theere any whitepapers, configuratiuon examples, etc. for this situation that could make this setup easy? THanks.
