ACS v5.0 - H/W or S/W relase ?
Oct 4th, 2009
Hi, I am going to use ACS v5.0 H/W or S/W,
Could you give me any advice for the ACS v5.0 H/W or S/W …?
Do you have a comparison chart or link of the CISCO ACS 5.0 H/W and S/W release?
Can some help us? Thanks ,
Collin Clark Wed, 10/07/2009 - 10:27
The release is the same for S/W and H/W. One is an appliance and the other a virtual machine. If you don't run run VMWare I would suggest against purchasing the VM image. There is not much data out there, here is what I could find-
The one thing you might want to think about is whether or not you really need version 5 or if 4 will work for your requirements. You can read about the differences in the links above.
Hope it helps.
