CCA 2.1 - deleted AnyConnect pkgs during upgrade to 7.1.3
Oct 2nd, 2009
During 7.1.1 to 7.1.3 upgrade, the CCA deleted my AnyConnect pkgs.
I uploaded the pkg again, but still broken.
I configured through CCA, which meant I had to delete my current SSL, which it didn't recognize.  And, OF COURSE, it said it didn't recognize firewall settings so it couldn't finish the config.
I had to use CLI to add:
policy group SDM_WEBVPN_POLICY_1
   functions svc-enabled                               - when I change this to "functions svc-required" split tunneling doesn't work
   svc split include 192.168.0.0 255.255.255.0
   svc split include 10.1.1.0 255.255.255.0
   svc split include 10.1.10.0 255.255.255.252
   svc dns-server primary 192.168.0.2
Tomoo Esaka Fri, 10/02/2009 - 19:45
  • Cisco Employee,
If you configured SSL-VPN server through CLI, then you are correct that CCA will not recognize the OOB configuration. Is this a production system? Is restoring to factory default and reconfiguring SSL-VPN server and option for your setup?
Rgds,
Tomoo
oehveding Thu, 12/03/2009 - 00:17
Hi!
I'm trying to set up SSL VPN on a UC520.
Witch of the AnyConnect packages do I need to download for the installation in CCA?
Øystein
Steven Smith Thu, 12/03/2009 - 11:23
  • Gold, 750 points or more
You could try this one.
anyconnect-win-2.3.2016-k9.pkg
Related Content
