gogasca Mon, 10/05/2009 - 00:25
  • Green, 3000 points or more
1.3.6.1.4.1.9.10.19.1.1.4
cpmActiveDS0s OBJECT TYPE
SYNTAX Gauge32
MAX-ACCESS read-only
STATUS current
DESCRIPTION "The number of DS0s that are currently in use."
::= { cpmDS0Usage 4 }
MIB: CISCO-POP-MGMT-MIB
With this you will get how many are being used at that moment.
- .1.3.6.1.4.1.9.10.19.1.1.9.1.3
cpmDS1ActiveDS0s OBJECT-TYPE
-- FROM CISCO-POP-MGMT-MIB
SYNTAX Gauge
STATUS Current
DESCRIPTION "The number of DS0s that are currently in use for a particular DS1."
::= { iso(1) org(3) dod(6) internet(1) private(4) enterprises(1) cisco(9)
ciscoExperiment(10) ciscoPopMgmtMIB(19) ciscoPopMgmtMIBObjects(1) cpmDS0Usage(1)
cpmDS1DS0UsageTable(9) cpmDS1DS0UsageEntry(1) cpmDS1ActiveDS0s(3) 0 }
To actual match the instance the pattern is something like:
1.3.6.1.4.1.9.10.19.1.1.9.1.3.0.5 = controller t1 0/0:5
1.3.6.1.4.1.9.10.19.1.1.9.1.3.1.4 = controller t1 1/0:4
And with this, you will get how many are being used by each one of the sub-interfaces.
- DS0 high water mark
CISCO-POP-MGMT-MIB
1.3.6.1.4.1.9.10.19.1.1.8
The maximum number of DS0s ever used simultaneously.
- CISCO-POP-MGMT-MIB.
cpmDS1DS0UsageEntry will provide the active calls per DS1(T1/E1).
Regarding an application that you can use, I cannot recommend any code or software (other than our Cisco NMS products) since I dont know your requirements. For this info I really recommend you to contact you account manager and ask him for this tool or any snmp walker in the web can help you.
webstd.design Mon, 10/05/2009 - 03:00
This OIDs about current activity, but I want to know the status of ISDN PRI..
nesharm2 Mon, 10/05/2009 - 05:36
  • Bronze, 100 points or more
Have you tried
"callActiveGroup from the DIAL-CONTROL-MIB"
or
CISCO-POP-MGMT-MIB which has objects like cpmISDNCfgActiveDChannels.
or
CISCO-ISDN-MIB :
demandNbrPhysIf
