Router Reboot
Oct 4th, 2009
Hi ALL:
I have a small doubt
My 2800 router is getting continiously rebooting once i manually reload it ,otherwise it works fine without any issue.
This is the crash info:
CMD: 'control-plane' 11:44:06 IST Sat Oct 3 2009
CMD: 'banner motd C' 11:44:06 IST Sat Oct 3 2009
CMD: 'privilege exec level 1 traceroute' 11:44:06 IST Sat Oct 3 2009
CMD: 'privilege exec level 1 ping ip' 11:44:06 IST Sat Oct 3 2009
CMD: 'privilege exec level 1 ping' 11:44:06 IST Sat Oct 3 2009
CMD: 'privilege exec level 1 show ip mroute active' 11:44:06 IST Sat Oct 3 2009
Translating "active"...domain server (255.255.255.255)
11:44:06 IST Sat Oct 3 2009: Address Error (load or instruction fetch) exception, CPU signal 10, PC = 0x42372584
From this is conclude 2 thing that after execting command privilege exec level 1 show ip mroute active it reload .
So if i remove this command from the config wil the issue we resolve or i have to upgrade the IOS
Current release Version 12.4(11)XJ
cOMMAND IN RUNNING CONFIG
Chao
Vishwa
paolo bevilacqua Sun, 10/04/2009 - 23:28
  • Hall of Fame,
    Founding Member
If you want to use that command, you need to update.
vishwancc Sun, 10/04/2009 - 23:49
Hi P,
Thanks for the reply.
Are you saying that the router is crashing because of that command getting executed.
Vishwa
paolo bevilacqua Mon, 10/05/2009 - 02:50
  • Hall of Fame,
    Founding Member
May be, you would need to confirm with a stack decode.
Wilson Samuel Mon, 10/05/2009 - 09:27
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
Hi Vishwa,
Often the best way to diagnose a Router Crash is to work with TAC.
However, normally I would go ahead and upgrade the IOS after doing a FactFinding on the bugs/issues on the release I have already have and the one I would want to upgrade to.
Hope that helps.
Kind Regards
sam wilson
