Route maps problem
Oct 4th, 2009
I am trying to configure route maps in cisco 1811 router, one wan port connected to the internet and the second one with company network,
the vlan 1 interface is used to connect inside network,
some times I get reply from both links, but some times response stops from company network link or internet,
Is Cisco 1811 router sufficient for Policy Based Routing??
Please look into my config and advise..
version 12.4
hostname MTL-1811
boot-start-marker
boot-end-marker
enable secret 5 $xxxxxxxxxxxxxxxxxI/
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
resource policy
ip cef
ip domain name millat.com.pk
ip name-server 10.16.6.11
username Junaid privilege 15 secret 5 $xxxxxxxxxxxxxxxxxxxxxx0
interface FastEthernet0
ip address 192.168.95.65 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
ip address 192.168.218.2 255.255.255.0
ip nat outside
duplex auto
speed auto
interface FastEthernet2
interface Vlan1
ip address 192.168.74.1 255.255.255.0
ip nat inside
ip policy route-map company_network
interface Async1
no ip address
encapsulation slip
ip route 0.0.0.0 0.0.0.0 192.168.95.1
no ip http server
no ip http secure-server
ip nat inside source list internet interface FastEthernet0 overload
ip nat inside source route-map company_network interface FastEthernet1 overload
ip access-list extended go_vpn
permit ip 192.168.74.0 0.0.0.255 192.168.218.0 0.0.0.255
permit ip 192.168.74.0 0.0.0.255 192.168.217.0 0.0.0.255
permit ip 192.168.74.0 0.0.0.255 192.168.1.0 0.0.0.255
ip access-list extended internet
deny ip 192.168.74.0 0.0.0.255 192.168.218.0 0.0.0.255
deny ip 192.168.74.0 0.0.0.255 192.168.1.0 0.0.0.255
deny ip 192.168.74.0 0.0.0.255 192.168.217.0 0.0.0.255
permit ip any any
route-map company_network permit 10
match ip address go_vpn
set ip next-hop 192.168.218.254
control-plane
line vty 0 4
webvpn context Default_context
ssl authenticate verify all
no inservice
end
MTL-1811#
Giuseppe Larosa Mon, 10/05/2009 - 00:05
  • Hall of Fame,
    Founding Member
Hello Junaid,
I don't understand why you are natting towards your company it should be enough to route towards it.
I would remove the following line:
also just few static routes should be enough to reach company network IP subnets.
192.168.217.0/24
192.168.1.0/24
Hope to help
Giuseppe
junshah22 Mon, 10/05/2009 - 01:17
The company network is connected with carier VPN service,, they are using BGP with MPLS.... thats why I used this command...
Giuseppe Larosa Mon, 10/05/2009 - 02:27
  • Hall of Fame,
    Founding Member
Hello Junaid,
again an MPLS L3 VPN service usually can support your private address plan.
Check with your service provider
Hope to help
Giuseppe
junshah22 Mon, 10/05/2009 - 02:30
ok,, will talk to the service provider and will let you know very soon,,
thanks
