How to Enable Spanning-tree portfast on Cisco Cat2948G (R5000)
Oct 4th, 2009
Hi all.
please help!
i have a problem. i don't known command to enable Spanning tree portfast on Switch Cat2948G. please see information about IOS verison and Platform of device?
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Mon, 10/05/2009 - 00:12
Hello Doan,
being IOS based
int type x/y
spanning-tree portfast
int f0/5
don't use it on ports towards other switches
Hope to help
chidd Mon, 10/05/2009 - 05:33
the Spanning-tree portfast command not exist on this IOS.
this is problem that i need all of you help.
this devices is 2948L3 and very old.
with you want add some port in to vlan, you must using "bridge-group " command.
glen.grant Mon, 10/05/2009 - 04:14
Use "set port host" slot/port - port , such as 2/1-48 . The 2948G is a catos box.
Giuseppe Larosa Mon, 10/05/2009 - 04:45
Hello Glen,
in the attached sh ver:
System image file is "bootflash:cat2948g-in-mz.120-25.W5.27.bin"
this is an IOS box, isn't it?
Hope to help
glen.grant Mon, 10/05/2009 - 04:54
In one of cisco's smarter marketing moves they made a 2948G-L3 and 2948G layer 2 box which was based on the L2 cat 4000 box so you have basically have one or the other , the user would have to tell us what exactly he has. The L2 box actually runs Cat 4000 code. I went by the notion it said 2948G and not 2948G-L3 .
Giuseppe Larosa Mon, 10/05/2009 - 05:08
Hello Glen,
the scenario is the same as a C6500 in Hybrid mode there are actually two "devices" in the same box.
Best Regards
