Setting TOS bits !
Oct 4th, 2009
hi all. I am confused with the following issue pls guide me.
I have defined this acl
access-list 113 per icmp host 10.0.0.1 host 10.0.0.2 echo tos 3 log
access-list 113 per ip an an
Now from R1(10.0.0.1) i did an extended ping to R2(10.0.0.2) setting TOS bits to value 3 but no matches are detected in
show access-list 113.
Following is what i did
R1#ping
Protocol [ip]:
Target IP address: 10.0.0.2
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface:
Type of service [0]: 3
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 10.0.0.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/6/20 ms
R1#
On R2
R2#sh access-lists 113
Extended IP access list 113
10 permit icmp host 10.0.0.1 host 10.0.0.2 echo tos 3 log
20 permit ip any any (12812 matches)
R2#
I dont know if i have misunderstood tos byte or what but i think if i am setting tos bits to be 3, then why not its setting it ?
Originally i tested it via windows wireshark and got confused when tos bit wasnt being set properly
Pls guide me
Giuseppe Larosa Mon, 10/05/2009 - 00:10
  • Hall of Fame,
    Founding Member
Hello Ovais,
when you specify the TOS byte you need to specify the byte value.
so if you want match packets with IP precedence 3:
3 -> 01100000 as tos byte = 96 decimal
32*ip prec value is the rule
then to test it you need to set ip precedence using extented commands in ping
ping
Protocol [ip]:
Target IP address: 10.55.0.32
Repeat count [5]:
Type of service [0]: 96
Sending 5, 100-byte ICMP Echos to 10.55.0.32, timeout is 2 seconds:
Also packets locally generated on the router are not processed by an outbound ACL on the device
Hope to help
Giuseppe
