PSTN calls
Oct 5th, 2009
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
Hi All,
We are facing a problem while making PSTN calls to outside world using Cisco 2800 router configured as H.323 Gateway & integrated to Call Manager version 4.x.
On the router we have , VWIC-2MFT-E1 card on which PRI is terminated.
Setup was working fine but now when we call up, we need to dial two or 3 times before call gets matured.
router detail : c2800nm-spservicesk9-mz.123-11.T10.bin
can somebody guide on the same...
regds,
aman
Overall Rating: 4 (1 ratings)
KonradStepniewski Mon, 10/05/2009 - 02:11
  • Silver, 250 points or more
Check status of your e1 line.
Show controller e1 x/x brief and show isdn service.
you can run debug isdn q931 and check what's going on as well.
nesharm2 Mon, 10/05/2009 - 05:55
  • Bronze, 100 points or more
Aman,
Apart from good suggestions from konrad
good things to check
1.what changed if it was working before ?
2.Did you have "direct indward dial" command under pots dial peer ?
Justin Brenton Mon, 10/05/2009 - 08:45
Can you post the results of
sh isdn status
sh voice dsp
sh voice call summary
Do you know how many B and D channels you have on your PRI, could be possible that your using all the channels available on the PRI.
Justin
