10-05-2009 02:36 AM - edited 03-06-2019 07:59 AM
I have got a question about stack of the 3750 switch. I need to add one more member to the stack.
After configured the switches priority and downgrade the IOS version same to the master in 3750 stack.
then I connect the stack cable and power on the new 3750. then the boot process was hanged after the master election complete.
IOS (tm) C3750 Software (C3750-I9-M), Version 12.1(14)EA1a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 02-Sep-03 05:15 by antonino
Image text-base: 0x00003000, data-base: 0x0079DB54
Initializing flashfs...
flashfs[1]: 4 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 3388416
flashfs[1]: Bytes available: 12610560
flashfs[1]: flashfs fsck took 8 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback Tests : Begin
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
Waiting for Stack Master Election (around 20 seconds)...
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: No Cable found on stack port 2
POST: PortASIC Stack Port Loopback Tests : Begin
POST: Found Stack port 2 Down
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Election Complete
Switch 2 booting as Slave, Switch 1 elected Master
Waiting for Port download...<hang>
any suggestions about the case?
Weng Kin
10-05-2009 03:59 AM
Hello Weng,
the following document can help
or
However,
you need to close a ring topology it looks like a cable is missing
you need to add a cable from last added switch to the first.
OR there is a cable that is faulty or not correctly plugged.
Hope to help
Giuseppe
10-05-2009 04:12 AM
I would also advise you upgrade both boxes . 12.1.14EA1 has to be like the first IOS they ever put on those boxes and could be part of the problem . The latest is like 12.2.52 SG .
10-05-2009 12:01 PM
Glen,
I agree on the upgrade part; however, the 12.2SG is for Cat4500 - you'll need 12.2(50)SE3 as the most recent.
10-05-2009 03:02 PM
You are right I got the last letter wrong , just was doing it off the top of my head. Should be SE not SG .
10-06-2009 04:49 AM
Hi all,
After upgraded the IOS of the switches, it can be stackable now. Thanks for your help.
Weng Kin
