2 WSA's one certificate
Oct 5th, 2009
when i download a certificate from 1 WSA and install to a certain workstation, and it works.
but when that workstation switches to another WSA the certificate seem not working anymore.
is there any way to use the same certificate on another WSA?
if there is any existing thread, please tell me
JennieMorton Mon, 10/05/2009 - 20:52
You didn't say which certificate in particular, so this may or may not apply to you. In the System Administration chapter, see the section on "Installing a Server Digital Certificate" and see if that solves your issue.
rommel1981 Tue, 10/06/2009 - 01:36
are you refering to the basics on installation of certificates?
any1 else?
khoanguy Tue, 10/06/2009 - 21:49
Assuming you are downloading the Ironport server certificate to your client browser which did not trust the WSA, then you can either:
1. download/import two different certificate from two different WSA into your client browser and avoid the issue.
2. upload your own server certificate that the client browser trust to both WSA, and not have the client browser warn of untrusted certificate.
more on the install of server certificate in the user guide.
