10-05-2009 05:24 AM
Hi, is there any possibility how to purge all discrepancies which are already fixed? I know there is an Acknowledge option but would like to have an actual status without checking all the retired discrepancies.
Thanks for your ideas.
Solved! Go to Solution.
10-08-2009 08:46 AM
Data Collection must not be picking up the correct VLAN information. It would probably be best to open a TAC service request so Data Collection debugging can be enabled. Alternatively, if there is stale data in the ANI database, reinitializing it, then running a new Data Collection could resolve this. To reinitialize the ANI database, run the command:
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=ani dmprefix=ANI
10-05-2009 07:32 AM
Discrepancies which are fixed will automatically clear on the next Campus Data Collection. You can also restart Daemon Manager, then run a new Data Collection which will cause Campus to rediscover all active discrepancies.
10-07-2009 05:20 AM
Thanks for your info. It looks logically but in our case it does not work. The discrepancies were fixed long long time ago and also after a lot of Campus Data Collections it is still there. What do you recommend? Open a TAC?
10-07-2009 07:56 AM
What is one of the discrepancies which are still active (include all details)?
10-08-2009 03:49 AM
Type Trunk VLANs Mismatch
Severity Medium
First Found 30 Sep 2008, 12:18:44 CEST
Description [aaa,GigabitEthernet0/1], [bbb,GigabitEthernet8/5]
Detail This Trunk Link has ports with mismatching active VLAN sets.
Port GigabitEthernet0/1 on device aaa trunks following VLANs:
Device type and OS version of aaa:
Cisco IOS Software, C3550 Software (C3550-IPBASEK9-M), Version 12.2(40)SE, RELEASE SOFTWARE (fc3)
Port GigabitEthernet0/1 on device aaa does not trunk the following VLAN indices:
Index:9
Index:30
Index:15
Index:34
Port GigabitEthernet8/5 on device bbb trunks following VLANs:
Device type and OS version of bbb:
IOS (tm) s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF15a, RELEASE SOFTWARE (fc1)
SERVER1 present in VTP domain GEBC_3.193.44.7(T) and having index 15
PHONES3 present in VTP domain GEBC_3.193.44.7(T) and having index 9
SERVICE present in VTP domain GEBC_3.193.44.7(T) and having index 30
MGMT_SRV present in VTP domain GEBC_3.193.44.7(T) and having index 34
Note: This discrepancy does not hold good if devices on either end of the trunk support different number of vlans.
aaa#sh run int gi0/1
Building configuration...
Current configuration : 174 bytes
interface GigabitEthernet0/1
switchport trunk allowed vlan 9,15,30,34
switchport mode trunk
end
bbb#sh run int gi8/5
Current configuration : 262 bytes
interface GigabitEthernet8/5
switchport
switchport nonegotiate
no ip address
udld port
spanning-tree guard root
end
10-08-2009 08:46 AM
