Changing Callmanager Name & Password
Answered Question
Oct 5th, 2009
Right now our Callmanager was set to a default state and we want to change it for security reasons. Is this possible and what are the steps in making this happen?
In addition is it easier to change the password vs. the profile?
Correct Answer by Rob Huffman about 7 years 8 months ago
Hi Robert,
Yes, sorry I missed that part :)
Try this great, great post from Michael @ Cisco it covers changing all of the CUCM passwords in 6.x,7.x versions;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified Communications and Video&topic=IP Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB?cmd=display_location&location=.2cc0bd9a
Hope this helps!
Rob
PS: If you are running a CCM 4.x version let us know.
Overall Rating: 5 (2 ratings)
Rob Huffman Mon, 10/05/2009 - 05:54
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Robert,
The Hostname change is not supported in CCM Versions prior to CCM 6.1(2):). I have dealt with some "rebels" who defied these threats and regret the fact they did. You can change the IP Address (see below docs);
Note: It is not supported to change the hostname on the Cisco CallManager server because the Structured Query Language (SQL) database does not support the hostname change. This is because SQL uses the server name for many of the tables related to Cisco CallManager and exchanges this information as such with the operating system. When SQL server is installed, it binds the database to both the machine and Cisco CallManager server names. If this is changed, the database does not replicate properly since the new Cisco CallManager or machine name is not updated correctly by SQL. **If a hostname change is inevitable, then the entire Cisco CallManager must be rebuilt.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094601.shtml
Prior to Cisco Unified Communications Manager Release 6.1(2), you cannot change the host name of either the publisher node or subscriber node after it is installed. If you must apply a new host name to a server, you can delete the server from Cisco Unified Communications Manager Administration (System > Server) and then reinstall the server with a new hostname. Also, be aware that a DRS backup that you take from a server with a particular hostname cannot be restored on a server (either a publisher or subscriber node) with a different hostname, even after you reinstall that node.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/6_1_1/ipchange/ipchg611.html
Changing the Hostname of Cisco Unified Communications Manager Servers
Starting with this release (6.1(2)), you can change the hostname of the first node or any subsequent nodes in the Cisco Unified Communications Manager cluster. You can only change the hostname of the first node from a subsequent node. The Cisco Unified Communications Operating System Administration user interface populates the hostname field on the Ethernet Configuration window and the Publisher Configuration window with the existing values. You can change the IP address or hostname of servers using the set network cluster publisher ip or set network cluster publisher hostname CLI commands.
Caution Resetting the hostname will cause your system to reboot and you may lose connectivity with the first node and the network. Before attempting to change the hostname of a Cisco Unified Communications Manager server, refer to the Changing the IP Address and Host Name for Cisco Unified Communications Manager Release 6.1(2).
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp401012
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/6_1_2/ipchange/ipchg612.html#wp185050
Hope this helps! Cheers!
Rob
rbill1967 Mon, 10/05/2009 - 05:58
Okay if not the hostname, what about the password? Can the password be changed without causing any issues with the system?
Correct Answer
Rob Huffman Mon, 10/05/2009 - 06:13
  • Hall of Fame,
    Founding Member
Hi Robert,
Hope this helps!
Rob
