Cisco 857 dropping internet connection
Oct 5th, 2009
I have connected a Cisco 857 router to an ADSL line. Internet worked for a while, then the connection started dropping. I have tested with a different router (a Netgear) and the connection is stable.
The line is adsl 2+, and I have loaded the latest firmware (adsl_alc_20190.3-0-33.bin) but this has not helped.
I ran the command "show dsl interface atm0" and have attached the results.
Can anyone advise what could be causing the problem?
Nick
Giuseppe Larosa Mon, 10/05/2009 - 10:14
  • Hall of Fame,
    Founding Member
Hello Nick,
I remember this issue.
I see the following:
Noise Margin: -6.5 dB
in DS ( CO to you direction)
noise margin should be expressed as a positive number in DB
this means noise would be stronger then signal
but at the same time we see
Output Power: 18.5 dBm
Attenuation: 18.5 dB
I would try if possible with another DSL module, this looks like troubled.
Hope to help
Giuseppe
