OSPF Issue - Static Works
Answered Question
Oct 5th, 2009
I have BackBone_Switch connecting to MPLS_RTR but using OSPF traffic doesnt flow using static routes it works.
BackBone_Switch
vlan15
name Uplink to MPLS_RTR
Interface VLAN15
IP address 192.168.150.1 255.255.255.252
interface fa 4/20
switchport access vlan 15
router ospf 250
network 192.168.150.1 0.0.0.3 area 0
MPLS_RTR
interface fa 0/1
description Connected to BackBone
ip address 192.168.150.2 255.255.255.252
Router ospf 250
network 192.168.150.2 0.0.0.3 area 0
UA_DC#sh ip ospf neighbor
Neighbor ID Pri State Dead Time Address Interface
10.10.10.1 1 FULL/DR 00:00:33 192.168.150.2 Fastethernet0/1
Any help
Correct Answer by Richard Burts about 7 years 9 months ago
Amin
The additional information that you have posted is helpful. From it we can determine tht the MPLS router has one active OSPF interface, which is the interface that connects to the switch. So the only routes that OSPF can learn via OSPF are routes from the switch.
OSPF is redistibuting routes from BGP and this line indicates that this should be working:
Number of external LSA 189.
I would expect some OSPF routes to be learned from the switch. There do not appear to be any. If you would post the output of the commands that I suggested from the switch we might get some insight into what is going on there.
Rick
Overall Rating: 3 (1 ratings)
Peter Paluch Mon, 10/05/2009 - 07:19
  • Cisco Employee,
Hello Amin,
What routes do you expect to see on the backbone switch? According to your output, the backbone switch is fully adjacent to the MPLS router so generally, there should not be any reachability problem, assuming that you have entered all the proper "network" commands into OSPF configuration so that all necessary networks are being advertised. Also, do you use any VRF tables?
Best regards,
Peter
Amin Shaikh Mon, 10/05/2009 - 08:50
We have couple of networks on BAckbone Switches and couple of networks are learned by MPLS Router.
All advertized on same OSPF ID but are not reachable.
I have not displayed those on the early post.
I have network 192.168.199.0/24 on mpls network.
If I perform sh ip route | incl 192.168.199.0
OUTPUT : no routes to destination, with static entry its fine.
what could be the other reason
Is there any other checks for OSPF
I have also done the following
clear ip route *
clea ip ospf proc *
No luck
Richard Burts Mon, 10/05/2009 - 09:46
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Amin
You have not provided enough detail to allow us to figure out what the problem might be.
What you have showed us so far is the configuration of an OSPF process with a single network statement. The result of this single network statement is that the MPLS router and the switch become neighbors. You have not provided any other detail about any other routes? Are there additional networks learned by OSPF on the MPLS router? If so what are they? Are there any other network statements on the MPLS router? If so what are they? Are there any other OSPF neighbors on the MPLS router? If so what are they?
You ask if there are other checks for OSPF. I would suggest that you start with:
- show ip ospf
- show ip ospf interface
- show ip ospf neighbor
- show ip route ospf
If you do these commands it will provide good information about what is going on with OSPF. If you provide the output of these commands from the MPLS router and from the switch then it would give us good information to work from.
Rick
Amin Shaikh Mon, 10/05/2009 - 11:45
Rick,
Do you suggest any specific debug command to get some clue for the issue.
I have added the config and output
sh ip ospf neigh remains the same as stated in earlier post.
I m planning to upgrade IOS from 12.2 to 12.4 and I have another router 3800 with latest ios for some other purpose, will test with that as well.
BackBone_Switch
vlan15
interface Loopback0
ip address 1.1.1.1 255.255.255.255
Interface VLAN15
interface VLAN 22
description USER-FARM
IP address 192.168.3.1 255.255.254.0
interface VLAN 23
description SERVER-FARM
IP address 172.16.16.1 255.255.255.0
Interface VLAN 24
description Wireless network
IP address 10.10.250.1 255.255.255.0
Interface VLAN 25
Connected to DU-ISP
IP address 10.10.251.1 255.255.255.252
Interface VLAN 26
description Connected to Juniper-Firewall
IP address 10.10.252.1 255.255.255.252
interface fa 4/20
router ospf 250
redistribute connected subnets
redistribute static subnets
network 192.168.3.1 0.0.0.0 area 0
network 172.16.16.1 0.0.0.0 area 0
network 10.10.250.1 0.0.0.0 area 0
network 10.10.251.1 0.0.0.0 area 0
network 1.1.1.1 0.0.0.0 area 0
ip route 0.0.0.0 0.0.0.0 10.10.252.2
MPLS_RTR
interface Loopback0
ip address 172.16.17.1 255.255.255.255
interface fa 0/1
interface fa 0/0
description Connected to SP-NET
ip address 172.39.109.198 255.255.255.252
Router ospf 250
network 172.16.17.1 0.0.0.0 area 0
redistribute bgp 68909
router bgp 68909
no synchronization
bgp log-neighbor-changes
redistribute static
redistribute ospf 100
neighbor 172.39.109.197 remote-as 68900
neighbor 172.39.109.197 route-map
no auto-summary
MPLS#sh ip ospf
Routing Process "ospf 250" with ID 172.16.17.1
Supports only single TOS(TOS0) routes
Supports opaque LSA
Supports Link-local Signaling (LLS)
It is an autonomous system boundary router
Redistributing External Routes from,
bgp 68909, includes subnets in redistribution
Initial SPF schedule delay 5000 msecs
Minimum hold time between two consecutive SPFs 10000 msecs
Maximum wait time between two consecutive SPFs 10000 msecs
Minimum LSA interval 5 secs. Minimum LSA arrival 1 secs
LSA group pacing timer 240 secs
Interface flood pacing timer 33 msecs
Retransmission pacing timer 66 msecs
Number of external LSA 189. Checksum Sum 0x5F5365
Number of opaque AS LSA 0. Checksum Sum 0x000000
Number of DCbitless external and opaque AS LSA 0
Number of DoNotAge external and opaque AS LSA 0
Number of areas in this router is 1. 1 normal 0 stub 0 nssa
External flood list length 0
Area BACKBONE(0)
Number of interfaces in this area is 1
Area has no authentication
SPF algorithm last executed 01:06:22.200 ago
SPF algorithm executed 962 times
Area ranges are
Number of LSA 37. Checksum Sum 0x11E07C
Number of opaque link LSA 0. Checksum Sum 0x000000
Number of DCbitless LSA 0
Number of indication LSA 0
Number of DoNotAge LSA 0
Flood list length 0
MPLS#sh ip ospf interface
FastEthernet0/1 is up, line protocol is up
Internet Address 192.168.150.2/30, Area 0
Process ID 100, Router ID 172.16.17.1, Network Type BROADCAST, Cost: 1
Transmit Delay is 1 sec, State DR, Priority 1
Designated Router (ID) 172.16.17.1, Interface address 172.20.3.42
Backup Designated router (ID) 1.1.1.1, Interface address 192.168.150.1
MPLS#sh ip route ospf
Correct Answer
Richard Burts Mon, 10/05/2009 - 12:37
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Amin
Rick
Amin Shaikh Mon, 10/05/2009 - 22:28
I upgraded the IOS Version 12.3(11r)T2 and reapplied the OSPF config again and it starts working.
Its weird
Thank you rick and all guyz
