DND and Hunt Groups
Do you know if there is any type of special configuration or conflict that can arise from DND and members of hunt groups….
I’ve got a client with an Office Manager who has 2 phones….one at the office and one at home.
She is also a member of a sequential hunt group.
For some reason her DND button is not available. It shows up in the Soft-keys but if she presses it nothing happens. She is using a 524G at home and work.
Here are the config snips:
ephone-hunt 50 sequential
pilot 2261
list 1802, 1803, 1801
final 2099
timeout 16, 16, 16
no-reg pilot
statistics collect
description Clinton Office Queue
ephone  10                         ///HOME PHONE
device-security-mode none
video
mac-address 0021.1BFC.A4FA
ephone-template 16
max-calls-per-button 2
type 524G
button  1o10,19,20,40
ephone  1                            ///OFFICE PHONE
video
mac-address 0021.1BFC.A4FB
ephone-template 16
username "BArnold" password 12345
type 524G
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 5
sdspfarm tag 1 confprof1
conference hardware
video
em logout 0:0 0:0 0:0
fxo hook-flash
load 7914 S00105000300
load 7915-12 B015-1-0-3
load 7915-24 B015-1-0-3
load 7916-12 B016-1-0-3
load 7916-24 B016-1-0-3
load 7906 SCCP11.8-4-2S
load 7911 SCCP11.8-4-2S
load 7921 CP7921G-1.2.1
load 7925 CP7925G-1.3.1
load 7931 SCCP31.8-4-2S
load 7936 cmterm_7936.3-3-16-0
load 7937 apps37sccp.1-3-2-0
load 7960-7940 P00308001000
load 7941 SCCP41.8-4-2S
load 7941GE SCCP41.8-4-2S
load 7942 SCCP42.8-4-2S
load 7945 SCCP45.8-4-2S
load 7961 SCCP41.8-4-2S
load 7961GE SCCP41.8-4-2S
load 7962 SCCP42.8-4-2S
load 7965 SCCP45.8-4-2S
load 7970 SCCP70.8-4-2S
load 7971 SCCP70.8-4-2S
load 7975 SCCP75.8-4-2S
load 521G-524G cp524g-8-1-16b
load 525G spa525g-7-1-9
max-ephones 32
max-dn 128
ip source-address 10.1.1.1 port 2000
max-redirect 20
auto assign 10 to 43
auto assign 5 to 8 type anl
calling-number initiator
service phone videoCapability 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message ABS , AINS & SIA
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
time-zone 8
live-record 2096
voicemail 2099
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$iEX7$jMp2ZiDgS7XWamiEWoHMI.
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6.... blind
secondary-dialtone 9
create cnf-files version-stamp 7960 Oct 01 2009 23:26:18
Steven Smith Wed, 10/07/2009 - 07:35
  • Gold, 750 points or more
Can you post the config for ephone-template 16?
ephone-template  16
service phone pcPort 0
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Meetme Gpickup Callback
softkeys connected  Park Endcall Trnsfer Hold TrnsfVM LiveRcd Confrn ConfList RmLstC Acct
Please note, that each of the sequential hunt groups in question have 3 members. The other users seem to be OK....their DND works.
Also, this particular user has three phones......one at the main office, and one at a remote office, and her home phone.
The main office has a username/password configured, but the other two do not.
Just additional FYI. I'm attaching the full config from this UC520.
ronlewis Fri, 11/13/2009 - 13:55
  • Cisco Employee,
Shared lines in hunt group can't have DND, from the CME admin guide;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmednd.html#wpmkr1010332
Restrictions
•Phone users cannot enable DND for a shared line in a hunt group. The soft key displays in the idle and ringing states but does not enable DND for shared lines in hunt groups.
User wants three phones, one in each location to ring so she can pickup no matter where she is.
Parrellel/blast hunt group might be better choice here then using overlays in a regular hunt group.
Also to be clear on the commend;
hunt-group logout [hlog|DND],
This command tells the phone to use HLog Softkey or DND to cause the DN to not ring new calls from the hunt group.
if not enabled under telephony-service, by default DND stops calls from ringing the phone only,
if enabled with Hlog feature, then Hlog will stop calls from hunt group ringing, call direct to the DN will still ring.
if enabled with DND, then DND will stop both hunt group and direct calls to ring.
see this section for details;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1130731
Understand with overlays though, the DND is only for the top DN, so the first DND would be muted, but calls to the second DN I believe will still ring, which may be of issue for this customer.
So Parrellel/blast hunt group is better way to go...
Ron Lewis
Cisco
Brikers12 Fri, 12/17/2010 - 18:03
how does one enable "HLog" for users in a hunt group?
I added the HLog to the ephone-template softkeys, what else needs to be done?
