Unity 4 failover setup
Answered Question
Oct 5th, 2009
I have a quick 'sanity check' question for someone who spends more time in Unity then I do.
I am nearly finished rebuilding a pair of Unity 4.2(1) onto new hardware and OS. My primary is done and active, my secondary is rebuilt with no database.
Can I configure fail over at this point, or do I need to DiRT restore a database onto the secondary first?
Also, when I run FailoverConfig.exe will the Primary go offline for part of the process? The docs I'm reading aren't clear on this (at least to me).
Thanks for any help,
Mark
Correct Answer by Christopher McAlpin about 7 years 8 months ago
Yes, you can configure failover at this point.
You do not need to restore a DiRT backup to the secondary server. When you run the Failover Configuration Wizard (FCW), the SQL database will replicate from the primary server to the secondary server.
Running FCW on the primary and secondary servers will briefly stop and re-start the Cisco Unity services.
Overall Rating: 5 (1 ratings)
Correct Answer
Christopher McAlpin Mon, 10/05/2009 - 10:14
  • Cisco Employee,
