Oct 5th, 2009
I'm trying to trigger accounting notifications from an ISG Router to a Radius Server.
Whenever a IP Session is created or deleted accounting notifications should be sent to the radius server. The problem is that the aaa accounting messages are not being sent to the server.
The following configuration is applied:
aaa new-model
aaa accounting network ISG start-stop group radius
aaa session-id common
ip dhcp pool test
subscriber feature accounting send ssg-compatible-vsas
call rsvp-sync
no scripting tcl init
no scripting tcl encdir
class-map type traffic match-any account
policy-map type service ACC
class type traffic account
accounting aaa list ISG
interface GigabitEthernet0/1
ip address
media-type rj45
speed auto
duplex auto
negotiation auto
ip subscriber l2-connected
initiator dhcp
radius-server host auth-port 1645 acct-port 1646 key cisco
radius-server vsa send accounting
The AAA debug output is the following:
2d18h: AAA/ACCT/HC(00000038): Register IEDGE_IP_SIP/C900002A 846Mbit/s, poll every 30.3000s
2d18h: AAA/ACCT/HC(00000038): Update IEDGE_IP_SIP/C900002A
2d18h: AAA/ACCT/HC(00000038): IEDGE_IP_SIP/C900002A [init-sess] (rx/tx) base 0/0 pre 0/0 call 0/0
2d18h: AAA/ACCT/HC(00000038): IEDGE_IP_SIP/C900002A [init-sess] (rx/tx) adjusted, pre 0/0 call 0/0
2d18h: AAA/ACCT/EVENT/(00000038): CALL START
2d18h: Getting session id for NET(00000038) : db=64EC2680
2d18h: AAA/ACCT(00000000): add node, session 46
2d18h: AAA/ACCT/NET(00000038): add, count 1
2d18h: AAA/ACCT/EVENT/(00000038): IPCP_PASS
2d18h: AAA/ACCT/NET(00000038): Method list not found
Does anybody have had any similar experience? why "method list not found" is appearing in the debug message?
Jatin Katyal Mon, 10/05/2009 - 10:42
Looking at currect config, everything seems fine.
What version are you running on?
You may check this bug:
CSCsk94472 iEdge-QoS:Service accounting info is missing in"show subscriber session"
Duplicated by:
CSCsm75945 The accounting method-list is not applied correctly on ISG.
javiercastro Tue, 10/06/2009 - 06:39
I have just upgraded to 12.2(31)SB16 and still behaving the same way :(
According to the Bugs you mention, the problem should be fixed already in 12.2(31)SB12.
Do you have any further ideas?
chrmar Thu, 10/15/2009 - 14:01
You have not defined the method list ISG:
aaa group server radius ISG
server auth-port 1645 acct-port 1646
(assuming you want to use that radius server for accounting)
