asa 5510 asdm 6.21 ios 8.2 - configure redundant isp's
Oct 5th, 2009
asa 5510 8.2(1)11 asdm 6.21
I have two separate ISP connections I would like to use for redundancy. THE ASDM above has the option to configure redundant interfaces, and it works without much config, if both interfaces are DHCP. How do I configure one ISP using DHCP (address reservation) and the second ISP with a static IP? The new ASDM almost makes it simple, but there is no option to configure the interfaces once they are redundant. I can go to the CLI if I need to do that.
I have it set up with the DHCP ISP now and if I plug and unplug that ISP from the 1st redundant to the 2nd redundant port it works (picks up the IP)...
Giuseppe Larosa Tue, 10/06/2009 - 04:19
  • Hall of Fame,
    Founding Member
spectracs Tue, 10/06/2009 - 17:08
Apparently I will have to try something similar. I was hoping the new ASDM/IOS with it's right-click ability to choose "redundant" configuration was going to be the solution.
